Hi everyone, thanks for looking through and the advice ahead of time. I have a shoot fast approaching and I'm debating the best way to light my exterior scene for an upcoming commercial. We will begin shooting early morning and we will see a family enter an amusement park from one angle where the sun is backlighting them - and then we will need to reverse the camera to see their POV.
It will be a very sunny day I'm sure with no clouds so we should get some nice backlight. I'm debating however whether to front lit with a large ultra bounce (20x20 or 12x12) using the sun to light the family of 4 as they walk in (Wide - Full shot of family - then MID CU of each member). OR if I should also blast some M40s/M90's into the ultra bounce OR light them using 2 of these lights with diffusion frames or softboxes over them.  The location has access to 63 amp power so we could run cables to take this power. I want a high key commercial look but want to go down the wisest route here. I have attached a sketch (actual location) in order to get a better idea....
I also plan to use a Job at the back of the family at the end of the street for an establishing shot...
1400943501_FamilyEnter-SunBacklight-JPEG-min__1556492749_5_30_118_151.jpg.28109e08165bad20d766b621ec102f0b.jpg
Also after I get this I will have to move the camera around facing a street of performers so they will all be front lit by the sun. I could film this first in order to get a more pleasant look with the sun being lower (Maybe use the Frames with Diffusion in case of any camera shadow if need be) and then film the family. Reference Picture attached...
Any thoughts you may have on this or experience with similar setups would be super. Cheers all!
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Tai Audio
