Lighting
You can see on the floor reflection that the windows are very much taller than appear in this frame.  It's possible that the entire shot was lit with light coming through the window at the front of the room, with maybe, some little ambience added inside the room, but it's hard to tell.  It's also possible that some augmentation of the window light is rigged above the frame, but it's not possible to know this from looking at this image.
It's also possible, but unlikely if there was a significant scene to shoot here, that this is natural daylight only, available light as well.  But, upon further viewing, it seems there is also some spotlight on the people near the wall at the back of the frame... ?
Link to comment
⬆️ this
And a bit of haze. The location makes the shot.
If you look closely at the reflection on the floor, there is a reflection spot that is brighter than the sky. An 18K straight through the windows aimed slightly frame left would be the usual suspect.
  • Upvote 1
Link to comment
