Ruben Arce
Can you help me identfying this Perfectone Motor?
I just got an Eclair NPR for a great price, and it came with this Perfectone Type MC 1440 C motor. I have done a lot of research and I couldn't fine any information about this motors. I read all the topics that I could find here in the forum and I found some interesting but mixed information. I understand the original motor didn't have any lights or switches. This motor that I have has a little bulb and it has a switch, for that reason I guess the motor was modified, but I don't know if it's Crystal Sync and I have no idea what the switch does. The XLR connector is a 5 Pin connector. I read at least two versions of the manual and it doesn't mention 5 pin connectors, it mentions that the Perfectone has a 4 pin connector. I learned by searching the threads here that some motors worked with an external box, but I have no idea what was it's function, I saw a picture of one of those boxes and it has a 4 pin Cannon connector too, so I'm confused.
IMG_1660IMG_1661IMG_1662IMG_1663IMG_1664IMG_1665IMG_1666IMG_1667
As shown in the picture of the removed Cannon connector at the base there are 5 cables coming out of the motor, I guess the two thin green ones carry pulse tone and the 3 thicker ones are the most important in terms of power, one is red which is the thickest one, one is purple and one is orange. Purple is soldered to pin number 1,  orange goes trough the main power switch and ends up at pin number 4 and the red one goes trough the switch as well and ends up soldered to pin number 5. I'm going to test with a multi meter, but just looking at the circuit I think red is +, purple is - (coonected to pin 1 as the current standard) but I have no idea what the orange one does. Of course I want to replace the connector with a 4 pin standard so any help with that is welcomed too.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • The Original Slider
    Just Cinema Gear
    FJS International
    G-Force Grips
    Cinematography Books and Gear
