Scott Quimby
Color testing Yugi BC Series Bi-color ribbons
Hi all!
       Just joined the site today so I figured I'd come out of the gates with something useful. I've been building a ribbon light kit and have purchased a few different brands of strips. The most useful ribbon will be the bi-colors so I will give you a rundown of how they perform. Yugi has a good name so I got production to buy a few reels of the BC series bi-color ribbon. I purchased 3 bi-color dimmers directly from Yugi as well. The $90 dimmers are great, as long as you aren't trying to go with a battery setup. They take an AC cable directly so there isn't a separate power supply going to a dimmer. The power supply/dimmer units have two knobs, one for dimming and one for color mixing. Yugi claims that they are flicker free to 240fps. I have tested mine to 60fps with no flicker. This dimmer is the cheapest price I could find for this functionality. The dimmer/power supply and ribbon are both 24 volt.
      The ribbon performs pretty well for $100. I have included screens from my Sekonic C-800 color meter to show the performance. I tested at full brightness in tungsten, daylight and mixed modes. I then did the same readings at about half brightness. I like that the LEDs cover a wide color range. Full Tungsten is at about 2700k while full daylight is around 6650k. It's a very useful range. I've also been happy with the color rendition in general and on camera everything has looked good so far. It's not perfect but great for the money.
     Here is the breakdown of the screenshots: Full power tungsten, then daylight then mixed followed by half output tungsten, then daylight then mixed. But first I'll lay it out in print.
Full Power:
Tungsten:
2720k
TLCI: 98
1560fc
CRI: 95.7
6643k
TLCI: 95
1920FC
CRI: 94
Mixed:
4477k
TLCI: 98
1810FC
CRI: 92.4
Dimmed half (by foot candles roughly, not based on knob position, which is more like 3/4 power) :
Tungsten:
2714k
TLCI: 98
738FC
CRI: 95.7
Daylight:
6570k
TLCI: 95
949FC
CRI: 94.5
Mixed:
4438k
TLCI:98
944FC
CRI 92.9
It looks like I can only upload 1 image at a time. I'll do a few. this one is full power, full tungsten.
Edited by Scott Quimby
Share this post
Link to post
Then on to the half output readings. This is tungsten with the dimmer dialed down to half the full output in foot candles. FYI, the knob on the dimmer is at about 3/4 full.
Share this post
Link to post
You can see that the tungsten colored LEDs perform a good deal better throughout the range compared to the cooler side. Overall, I feel comfortable using these ribbons for film. I have used them a few times already, but the implementation has been unique. One use was a back light halo effect and the second was creating a TV glow on faces. These were not perfect color dependent uses.
These ribbons and power/dimmer units do represent a good value. I have other metrics if anybody is interested. I can send the TM-30 info or spectral distribution graphics.
Share this post
Link to post
Nice. Based on the results, it seems like it can hold up compared to other leading LED competitors.
How far were you from the source when reading?
Share this post
Link to post
When the R9 and R12 numbers get down into the 70s, you're talking about something that's certainly not at the absolute best levels currently available. I'm slightly surprised that they're measuring such high TLCIs with those spot colour deficiencies.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Serious Gear
    Just Cinema Gear
    FJS International
    G-Force Grips
