Aaron Martin @ OH Posted June 8, 2019 Share Posted June 8, 2019 (edited) Hi, I think I remember the analog workflow for going for creating a work or release prints from a reversal source, but I'm posting here to double check: - start with camera original - create internegative - strike work print from internegative - match back to internegative and conform for release prints or I could - edit camera original (with glue) - create internegative from edited footage for printing Is that correct? Thanks! Edited June 8, 2019 by Aaron Martin @ OH Link to comment Share on other sites More sharing options...
Dirk DeJonghe Posted June 8, 2019 Share Posted June 8, 2019 One problem with cutting the internegative is that you can only get polyester base stock. Splicing is only via ultrasonic splicers, not known for high quality splices. The alternative is to use pull-processed and pre-flashed camera stock such as 7203 or 7213. Note: the current 'official' internegative also benefits from preflashing and pull process. Link to comment Share on other sites More sharing options...
Premium Member Simon Wyss Posted June 9, 2019 Premium Member Share Posted June 9, 2019 Still another way was via reverse prints off the original. Unfortunately some corresponding stocks have been discontinued some years ago, Eastman direct music preparatory film 5360/7360 and Eastman reversal black and white print film 7361. X360 didn’t afford the image quality of 7361. Both were on a colourless TAC base. If you have microfilm reverse duplicating film perforated, you can go this route. All microfilms are on polyester base. Link to comment Share on other sites More sharing options...
