50Hz / 6oHz frequency conversion issues (?) ARRI S 16MM ANIMATION MOTOR
MONO NO AWARE
Greetings community.
I'm on a trip in Israel, shooting with my ARRI S and DOM ANIMATION MOTOR / CONSOLE / CONTROLLER and there is a slight issue which I believe is being caused by the frequency difference of 50Hz here in Tel Aviv verses 60Hz where I tested and ran the motor.
When I set up the camera and animation stand the shutter would rest closed, and as each frame advanced it appeared to be giving me a full rotation and taking a single image, after about 20 or so frames, I noticed that the shutter was actually 'drifting' slightly out of alignment, eventually resting in the fully OPEN position.
Is this a matter of Frequency Conversion ?
Could it be another issue?
Solutions?
Thank you for your time and suggestions.
Link to comment
