David K Chavez
Complete Aerial Cinematography Kit: Alta8, MoviPro, MoviController, Teradek, ....
For sale is a complete RTF heavy lift aerial photography kit, including all components necessary to operate in a set environment. All gear was purchased in mid 2018 to mid 2019. Total investment was north of $52,000. The centerpieces are the Freefly Alta 8 and MoviPro Aerial Bundle. Gear was cared for meticulously and is in like new condition. Asking $35,000 for everything. I will also offer basic training on the set up and operation of the gear if you are located within a reasonable distance from Southern California. Items included are as follows:
Note: click blue text for pictures
Drone:
Drone Batteries/Charger:
  • (16) Tattu 12,000mAh 15C Lipopolymer Batteries (8 sets)
    • Maintained log of life cycles to monitor health, the most heavily used batteries still have a predicted 85% life remaining to function at full capacity (based on 200 cycle lifespan)
  • Rotor Craft Custom Charger Case
    • Mounted in Nanuk 930 weather resistant case: Revolectrix DPL6-T charger, Meanwell RSP2000-24(capable of 2000W on 220V outlet), step down converter, DPL wire kit, also included are 2 parallel charging boards-makes it possible to charge 12 batts simultaneously), EC5 charge leads, power cable (for standard 120v outlet), voltage checker
  • (2) 1510 Pelican Storm Cases (in OD Green)
    • Used to transport batteries
Gimbal:
Downlink
Gimbal Control Station Rig:
Monitors:
Power:
Comm:
Link to Photo Album
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Serious Gear
    FJS International
    G-Force Grips
    Just Cinema Gear
    Cinematography Books and Gear
