Max Field
Wall Spreader Weight limit?
I have a wooden 2x4 wall spreader, about 11.5ft wide. If it's going into dry-wall, what exactly is the weight limit before it begins to slip?
Share this post
Link to post
Will the load be at the center of the 11 and a half feet or more towards one end?  That will be one factor in determining the amount he wood will defect at a given load.  What type of wood? SPF, "white wood", something else?  Kiln dried or S-Grn?  Are the base plates of the spreader directly over  a stud or do you intend to use scabbing to bridge the studs?
Share this post
Link to post
His test is the spreader up against a plywood wall.  A different scenario than the same spreader against a plaster or sheetrock wall. The plywood isn't going to crush or crumble as pressure is applied.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Wooden Camera
    Just Cinema Gear
    FJS International
    G-Force Grips
    Cinematography Books and Gear
