how to remove the viewfinder (bolex h16 reflex)
Richardson Leao
So you have a RX-3, big base, T-I lever.
To remove the finder you first undo the four screws in the tube cover. Then you can pull the cover towards the front and up. If never opened, it will have (most certainly) rotten foam rubber underneath.
After that you flip the finder dowser up and undo the four large-head screws on the tube base. Then you lift the tube vertically off with a little wiggling. On reassembly make sure the ocular slot coincides with the stud on the rear mounting plate.
Link to comment
  • 1 year later...
  • 3 years later...
