Stephen Lewis
Light panel and diffusion frame on same stand
I'm doing food shoots in tight spaces like kitchens and dining areas in restaurants.  I have some Clar Luxpando LED panels which i love but since they are panels and don't have bowens mounts I can't just slap a softbox on the front.  To minimize the footprint of my lighting gear, can you recommend a way to rig a diffusion panel to the lightstand itself? Some of these areas are pretty tight and I'd love to avoid placing a c-stand with diff for each light.
Share this post
Link to post
On 9/9/2019 at 11:26 AM, Ed Conley said:
Those are very small and fiddley. Not big enough to I'm thinking 24x36 or 30x36 frame. Is there some brilliant little bit of grip equipment that would let me rig a frame to the center riser if a c stand or light stand?
Share this post
Link to post
Light on the baby pin and Cardellini+Gobo Head+20” c-stand arm on the stand mast? Seems like a chimera would be simpler and take up less space, but there you go.
Alternately, what about building a custom diffusion box for the lights using frosted plastic? I think Litepanels made something like a plastic take out tray that velcroed to their 1x1 panels and stood out a few inches. Something like that?
Share this post
Link to post
Yes you can. One of my old Swedish gaffers used to use a C-stand with a flag arm at 45 degrees (and clamped in middle). At the knuckle end he put a 4x4 bounce card, at the pointy, other end of flag arm, he put a little Redhead light bouncing into the card. It was a single stand, moveable soft unit, almost like an umbrella light. Worked well. Today with LED soft units, it's less need for it, but good trick to know.
Share this post
Link to post
This is something I do all the time. Ain't nobody got time for dual-standage!
- Castor wheels for the stand (for rapid repositioning)
- Triple header to hold your lightsource(s) + grip head
-  Get an umbrella (sized to taste) with either Diffusion or White for bouncing into
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • G-Force Grips
    FJS International
    Just Cinema Gear
    Cinematography Books and Gear
