Sushanta Barman Posted September 12, 2019 Share Posted September 12, 2019 How can I set the 3:2 aspect ratio in view finder of f55 ? And if it can't be set how can I shoot in 3:2 aspect ratio ? Link to comment Share on other sites More sharing options...
Premium Member Mark Kenfield Posted September 12, 2019 Premium Member Share Posted September 12, 2019 I don't think you can set custom framelines on the F55. You'll need to get an external monitor or EVF that has that functionality. The Odyssey 7Q is great, it will let you create whatever aspect ratio you want. Link to comment Share on other sites More sharing options...
Premium Member Satsuki Murashige Posted September 13, 2019 Premium Member Share Posted September 13, 2019 12 hours ago, Mark Kenfield said: I don't think you can set custom framelines on the F55. Actually you can. Menu > VF > Marker > User Box. You will need some kind of framing chart to line up your user guides, since the numbers for setting the vertical and horizontal guides are just random. I’ve found the easiest way is to connect an external monitor that has the 3:2 (or 1.5:1) guides built-in. Output the camera’s frame guide overlays through the SDI port. Then just adjust the camera’s user guides until they line up with the monitor. 2 Link to comment Share on other sites More sharing options...
