Bernhard Kipperer
Bolex H16 MC-17 motor on batteries
I'd like to power a Bolex H16 MC-17 motor from batteries, I think I'll need 24V for 24 fps.
Does anyone of you have any experiences what types of batteries would work reliably to use the camera away from a wall socket? How much current is needed?
Maybe anyone has a link to such batteries so I could try to get them?
Thanks a lot!
Share this post
Link to post
I have used a couple of the same motors with a relatively inexpensive 24V Lithium Ion power tool battery made by a company called Kobalt. There's an ebay seller who casts up "docks" for these batteries:
Ebay Link
It works great! Two things to remember: the speed governor on your Bolex will still be regulating the 24fps, so make sure that is set correctly. Also the Lithium-Ion batteries are a bit finicky. You kinda always have to keep it charged between uses, otherwise they can go bad. I have had to replace it once.  Also make sure to insulate or cover your wires/connector when not in use, as 24V is a lot of juice and you don't inadvertently want to cause a short.
Edited by Webster C
  • Upvote 1
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Serious Gear
    FJS International
    The Original Slider
    G-Force Grips
    Just Cinema Gear
    Cinematography Books and Gear
