Manu Delpech Share Posted November 4, 2019 Hey there, I got the rates from the Kodak NY lab, and there's a small but still significant price difference, 4 additional cents between a HD scan and a 2K scan. Now, they only do scanning, so the HD one is not a telecine (which I would have assumed) but simply labeled at HD. Does anyone know how significant the quality difference would be? I've looked at HD telecine or 2K scan threads here before, but I've never seen an HD scan and wonder what the difference could be? They use a BlackMagic scanner, I'm guessing the Cintel? Quote Link to post Share on other sites
Robin Phillips Share Posted November 4, 2019 you should be able to ask them which scanner is which. I havent dealt with NYC but Atlanta has always been super helpful with answering questions. its possible the HD scan is on their blackmagic cintel scanner, which is actually less than 1080p. Quote Link to post Share on other sites
Tyler Purcell Sustaining Member Share Posted November 4, 2019 The blackmagic scanner has a native UHD resolution for Super 35mm. So the cost increase makes no sense, if they're using the same machine. They may have a old cintel for "telecine" work. Quote Link to post Share on other sites
Will Montgomery Sustaining Member Share Posted November 4, 2019 Lots of different opinions on the Blackmagic scanner. I believe it's fine for dailies, if you're looking for something you'd finish with you may consider some other options but perhaps best if you just do a test to make sure it's what you need. Blackmagic Scanner: UHD for 35mm, 2k for 16mm. The camera doesn't move so the sensor is basically cropped in for 16mm. Quote Link to post Share on other sites
Robin Phillips Share Posted November 4, 2019 apologies, my brain is so tuned to 16mm lately I made a bad assumption Quote Link to post Share on other sites
Tyler Purcell Sustaining Member Share Posted November 5, 2019 (edited) 4 hours ago, Will Montgomery said: Blackmagic Scanner: UHD for 35mm, 2k for 16mm. 1903 x 1143 for Super 16. So basically 1080p. 😞 Plus the imager is SO NOISY, when you crop it, damn thing looks like crap even if the resolution isn't great. For 35mm, it's OK, pretty decent in HDR mode. Edited November 5, 2019 by Tyler Purcell Quote Link to post Share on other sites
Manu Delpech Author Share Posted November 5, 2019 Thanks for the answers, I assumed HD is telecine, but they don't do telecine and Kodak works with Metropolitan in NY for the scan. So yeah, a bit odd. Was just told the 2K is slightly higher resolution which is obvious. I guess the best option is to simply go with 2K scanning for all rather than do an HD for all dailies (going for a 5 to 6:1 ratio) and then scan the selects at a higher resolution which would be dumb and waste money. It's a shame they don't offer telecine but their rates (0.22/ft for scanning for 2 perf) seem pretty good. Quote Link to post Share on other sites
Tyler Purcell Sustaining Member Share Posted November 5, 2019 Just as a side note, why not use Cinelab? Will you be shooting in New York? Quote Link to post Share on other sites
Manu Delpech Author Share Posted November 5, 2019 Shooting in New York, plus the Kodak NY lab kinda has great references between Spielberg and Scorsese 😄 Quote Link to post Share on other sites
Tyler Purcell Sustaining Member Share Posted November 5, 2019 1 hour ago, Manu Delpech said: Shooting in New York, plus the Kodak NY lab kinda has great references between Spielberg and Scorsese 😄 Ah yes true! haha 😛 Quote Link to post Share on other sites
