A woman sees the shadow of her deceased cat on the wall as the cat (unseen 'cause it's deceased) walks across the floor.  I'm looking at ways of doing this and none actually working for me.  If I could somehow project the shadow on the wall, I would do this in 16mm.  As it is, I may have to resort to digital & green screen.  I'm working with a couple of cats and lights just off the floor and getting some shots that come close enough to use but this is digital.  I'd be burning a lot of 16mm film with this process and my budget would be shot.  Any thoughts?  thanks, tom
Share this post
Link to post
If you need a moving cat shadow, might make sense to film the cat first and project the "shadow" with a video projector.Then you have complete control of the cat movement/timing etc..
Share this post
Link to post
Well, I'd try and do it for real and hope you don't burn a lot of film -- maybe bring multiple cats? Otherwise I agree with Phil.
If you can build a partial set, perhaps create a wall out of diffusion material and project the real cat's shadow from behind the wall to give yourself some room, plus that way the cat can be closer to the wall for a sharper shadow. You'd have to deal with the bottom edge of the wall though somehow, can you live with a shadow of the bottom wooden strip holding down the material.
Share this post
Link to post
I would have to see the storyboard, but it may be possible to film it,  with the cat walking by, and do a split screen, replacing the cat part of the frame with an empty floor.
Something like how they did that type of effect of shadows of the farm workers in the film Vampyr.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Just Cinema Gear
    FJS International
    G-Force Grips
    Cinematography Books and Gear
