Best monitor to use on a Arri SR3
Cale Boys
Hey Cale, I usually like to go with the small HD DP6 or DP7. They are cheap monitors yet sharp, and have composite signal input. If you get a composite to BNC adapter you can hook into the green composite on the monitor and get SD video signal.
This will also work with some TV logic that have the composite inputs as well.
https://storefront.brackemfg.com/storefrontCommerce/itemDetail.do?item-id=9337&order-quantity=1&item-index=0&customer-item=BM50366&order-uom=EA&warehouse-id=1&item-number=BM50366&customLen=&gclid=CjwKCAiAgqDxBRBTEiwA59eENxCkhXEjBIH7qmqITLkMgd34zYdtNHuQe2GsstsAbEYouHjW19J8WxoCd3kQAvD_BwE
Link to comment
16 hours ago, Cale Boys said:
Yeah fair enough, are HD monitors unless on an SR3?
Not useless, just double the cost of what you need to be paying. Only a few have composite video on them as well, so that kind limits what you can buy.
Link to comment
