david richardson
Pant and tilt heads for Eclair 16mm with lens
Hello any advice on a tripod head for my camera. I have a Manfrotto 229. But I fear this might not be strong enough. Any advice would be great. Keeping my budget low, but safe as I've seen some heads over a grand! I want to use it handheld mostly but Do want some thing stead for telephoto footage and some tripod movements.
Share this post
Link to post
1 hour ago, Brian Drysdale said:
If short of funds, a second hand or used tripod is the way to go. Which Eclair are you using, the NPR or the ACL?
Hi Brian, definitely going to go used. I'm using the NPR, which seems a bit bigger. My tripod is the Manfrotto 058b which looks stable enough, but I doubt the head is.
Edited by david richardson
Share this post
Link to post
In that case I wouldn't use anything smaller than a 100 mm bowl tripod with an associated head.  The NPR is a pretty top heavy camera and the only times I've used one we had 150mm bowl tripods.
Share this post
Link to post
The old film industry gear is well engineered and can outlast the new video heads
A Libec tripod suitable for an NPR probably costs more than your budget. The camera.weighs 21lbs and I don't know if that includes the lens. and it's not best to be working at the limit of your head.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Gamma Ray Digital Inc
    G-Force Grips
    FJS International
    The Original Slider
    Just Cinema Gear
    Cinematography Books and Gear
