Sean Dahlberg
1.66 finish super 16
I'm playing around with finishing super16 for a 2k 1.66 crop in Premiere Pro and I want to make sure I'm doing this correctly.  I believe a 2k finish for 1.66 would be a sequence size of 2048x1228 but when I do this I'm still seeing parts of the film gate, I have to scale up to 103% in order to get rid of it.  Now, I also made a sequence that was 1800x1080 and the image "fit" nicely into that but for some reason it doesn't feel like this is the correct sequence setting for a true 2k 1.66 finish.  If anyone can correct this brain fart I'm having it would be much appreciated, thank you!
Share this post
Link to post
The thing is 1.66:1 isn't supported in the standard DCP spec and most cinemas won't be set up for it, normally they would just have 2.39:1, 1.85:1 and maybe 16:9 for alt content.
The imager in most cinema projectors is 1.89:1, so if you made your file 2048 wide it would be cropped top and bottom, the projector chip isn't high enough for a 2048 wide 1.66:1 frame. It's only 1080 high in 2K
The usual approach is to pillarbox the 1.66:1 image within the standard Flat format of 1998 × 1080.  So your 1.66:1 frame would need to be 1792 x 1080 (if my maths is correct). Which is close to your estimation. You'd still need to make a 1998 x 1080 DCP with black bars down the side to maintain the 1.66:1 AR
For broadcast your 1.66:1 image would need to be in a 16:9 HD container - again 1792 x 1080 fits with black bars on the side to pad out to 1920 by 1080
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • The Original Slider
    Just Cinema Gear
    FJS International
    G-Force Grips
    Cinematography Books and Gear
