Aaton XTR - 16 volts battery for 54 fps
Hi !
I rencently bought an Aaton XTR and i am looking for solution to power my camera. I think the best solution is to put some V-LOCK battery but i don't know how to connect them on the camera !
I saw on the XTR manual that the voltage tolerance is from 10 to 18v. It means that i don't have to convert the voltage of the v-lock to 12v ? I can use it like that for every cameras speed ?
Last question, i saw that the camera needs a 16v battery for 54 fps ! It is right ?
If somebody with more experience could give me advice, i will be very grateful !
Thank you so much,
Maxime Berger
Link to post
It's recommended you use 12v batteries because the voltage regulators over heat when they are trying to shed the higher voltage. We use 14.4v Lithium NP1 style batteries and they've been fine over the years on the XTR. We also have some 16.4v and I prefer not to go that high. Amperage is the most important thing when it comes to the high speed running.
  • Like 1
Link to post
  • 8 months later...
Hi Frank!
I tried to run the camera at 54fps with a 12v battery and it works. Maybe it won't go up to 54 frames per second but you can do a slow motion anyway (not a regular one I think).
Link to post
  • 2 months later...
On 12/13/2020 at 12:10 AM, Maxime Berger said:
Hi Frank!
Hey Maxime hows it going.....what battery are you using then? My number's +34 711014545 whatsapp me as usual
Link to post
Hi Stephen. I finally make by myself a V-lock plate adapter to use V-lock battery on my Aaton. It was the best way to power the camera and the accessories easily!
Link to post
photos please
Link to post
  • 2 months later...
Thanks for the images Maxine. How does what you have done work. You have the original battery and what looks like a mount for another type on top....what have you done or what is the engineering part of what you have done that makes the battery work? I am ZERO electrical engineering-minded haha
Link to post
I connect the (+) pin of the Aaton XLR4 on the (+) pin of the V-lock plate with a cable. Then the same with the negative pin. After, I roughly tinkered with the original battery to hook the v-lock plate into it hahah.
  • Upvote 1
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
