Sign in to follow this
Pavan Deep
Kodak Ektar lens
I recently got a Kodak 16mm camera and with it came a 25mm Kodak Cine Ektar II lens, at first I didn't think of using this lens as it didn't look great,  but I discovered that he optics are very clean so I  used it and and have been impressed with it as it's incredibly sharp as good as or  perhaps even more than my Switar, my issue is that the focus is quite stiff. Can this be fixed?
Pav
Share this post
Link to post
I’d love to bring your lens back to life. My latest Kodak Ciné Ektar was a 102 mm that I could revive. I assume you have the f/1.4 since the f/1.9 has rare-earth glass that brings a tint. The f/1.4 is a seven elements design, about on par with the f/1.5 Cinor.
Share this post
Link to post
Ektar was the name Kodak gave to their top of the line Pro grade lenses.
the tint is some old lenses is often due to Thorium in the glass.  if minor it gives a slight Yellow (usualy) tint to the lens.  sometimes treating the lens (carefully) with UV light can remove the tint.
Share this post
Link to post
oh and the stuff focus, generally means the lubrication has broken down.  someone who knows the tricks has to dismantle the focus and clean out the old lube and put in fresh lubricant, and then reassemble and set the focus..
Share this post
Link to post
I have been out taking photos with it using my digital camera and I can't see a yellow tint I would love to have it sorted. How much would it be and is it worth it?
Pav
Share this post
Link to post
The yellowing is usually only very slight and you won't see it in the images due to the camera accounting for white balance. Repairing it isn't too hard or expensive. It would probably be well worth the cost, unless the lens is cosmetically ugly. The aluminum barrels of these don't age well as they get pitted and dull gray with age. It is a really good lens though as far as its performance.
Phil Forrest
Share this post
Link to post
I need to have a look at a lens in any case. Your Ciné Ektar might take two hours of continuous work. The time of parts lying in chemicals is of course not counted. PM, please
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Rig Wheels Passport
    FJS International
    G-Force Grips
    The Original Slider
    Just Cinema Gear
    Cinematography Books and Gear
