Jonathan O'Neill
Reflected material
Hi, just wondering if anyone had any tips and tricks / alternatives they used for budget reflected material?
Generally I'll use in descending softness: unbleached muslin , polyboard , Ultrabounce , white foamcore , silver floor insulation board ,  Thermawrap Foil Wrap , lee 273 silver reflector etc
I'm kinda looking for more materials to add a bit of a DIY "cine reflect lighting system" Does anyone use any light weight mirror like materials?
Cheers
Share this post
Link to post
The trick with reflectors that are intended to maintain beam quality is that they have to be very flat and rigid. The commercial cine-reflect system is made using what looks like the plastic-cored, metal-faced board used for things like shop signage and (somewhat notoriously) facing buildings, but I would imagine there's been some special effort made to ensure it's really flat. If it isn't flat, it'll have lensing effects (and that might be a perfectly valid way to operate) but that spoil your ability to extend throw in a compact space and reduce inverse-square falloff without compromising quality of light.
As to everything else, all my textiles are just stuff I bought from a fabric seller at an open air market.
Share this post
Link to post
Hi Phil, thanks for the reply. Yeah it's not really to achieve a perfect throw as such, a bit of an inconstancy in the mirror would be fine. I need to create a moon glow onto a bed from a window in a cramped small room with no access to outside the window. I'm looking to boom the mirrored material to the window and bounce on a light (setup all inside the room). I’ve found some sticky back plastic mirror stuff on Ebay I’ll give a try
Share this post
Link to post
Mylar, but being thin and flexible will have to be glued down to foamcore. Mirror like but not fragile  like glass.
Edited by JD Hartman
Share this post
Link to post
Ahh thanks JD, I wasn't famililar with Mylar looks really useful
Share this post
Link to post
35 minutes ago, Phil Rhodes said:
I think the fastest way to get it is "a space blanket"
They cost next to nothing and you may be able just to hang it, or tape it to the window frame. Fireproof, too.
  • Like 1
Share this post
Link to post
You could try looking at aluminum sheets from home improvement stores. You can sometimes find them in different finishes, and they can look interesting.
Share this post
Link to post
Wild idea, but also metallic spray paints like silver, chrome, gold, etc.
Share this post
Link to post
14 hours ago, Phil Rhodes said:
You can get the plastic-cored aluminium composite panel in a variety of finishes anyway
1500-3050mm-Sign-Aluminium-Composite-Pan.
Ahh nice, looks a bit like silvered foamcore. I've also found quite a bit of "perspex mirror" and "Vinyl mirror rolls" which could be stuck on to foam core. I also might try applying a matt spray to achieve a different quality
Share this post
Link to post
Some of the Cine Reflect Lighting System panels give a linier bounced light, have you seen any materials which give this look?
See attached image
1637644624_ScreenShot2020-07-30at10_30_54.thumb.jpg.0814c2f4c0aa8935a5ec699131b60d0f.jpg
Edited by Jonathan O'Neill
spelling
Share this post
Link to post
It's not quite foamcore, it's quite a bit harder and tougher than that. It's used for shop signs and on the outside of buildings.
I guess look around and see what you can find; I'd just google. With care you could probably use it as a backing for more or less any reflective media.
Share this post
Link to post
creating DIY reflectors is relatively easy and it's super fun to play with.
I have a large carton box. on one side I glued Aluminium  foil (the one you use in the kitchen) and on the other side I glued copper sheets. It works!
Edited by Abdul Rahman Jamous
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Ritter Battery
    G-Force Grips
    Just Cinema Gear
    FJS International
    The Original Slider
    Cinematography Books and Gear
