Loading LUT onto C500 mkii
I'm having trouble loading custom LUTs and picture profiles onto my Canon C500 mkii.
This is my process so far:
Load .cube LUT onto a formatted SD card (this SD card works fine as I recently used it to update camera firmware), put into SD slot, power camera, go to Monitoring setup>page 11>User LUT 1> once I click on any of the user LUTs, all options past that are greyed out. So I can't click on register etc.
A similar thing is happening when I try to load a custom picture profile, "Load from SD card" is greyed out.
Any help would be much appreciated.
Kind regards,
Tim.
Link to post
26 minutes ago, Tim Flower said:
Kind regards,
Tim.
Format the card first in the camera ..    SD card lock is on ?
Link to post
Yes, card formatted in camera first and card lock is off.
Link to post
Is it some thing like the user LUT can only be 1D and yours are 3D LUT,s..    I guess I would try another card as one form of illumination ..  can you get access to another C500II and see if the same happens ..  are you in custom maybe try EI
Edited by Robin R Probyn
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
