dio zafi
WTB ANAMORPHIC EYEPIECE MOVIECAM SL
2 hours ago, dio zafi said:
Hi
Want to buy ANAMORPHIC EYEPIECE for  MOVIECAM SL
As far as I know, they never made an anamorphic desqueeze option for the regular Moviecam SL viewfinder. You would need to buy a Moviecam Compact viewfinder system with the anamorphic eyepiece, as well as a VAP adapter plate to fit it on the SL. I’ve never done it before, but I assume it works ok. I’ve seen BTS stills of SLs kitted out that way.
There’s one guy from Belgium on eBay who has a complete kit for sale. I’ve considered it myself, but personally I can’t justify $5K USD plus customs tax just for a desqueezed optical image. Plus the guy was a bit rude, so I didn’t feel like doing business with him. But maybe you’ll have better luck.
Share this post
Link to post
Is there anyway around it
let’s say using the video tap image to de-squeeze the image
(otherwise I’m just going to have to get used to the image while filming)
Share this post
Link to post
Yes, just use a monitor with a de-squeeze function off the video tap. If your Video Assist is standard def (they all were originally), then you’ll need a monitor with a Composite Video input. Something like a TVLogic 5.6” or 7”. They don’t have a dedicated 2x de-squeeze function, so you can use the custom scaling function to approximate it. Because the monitors are 16x9 and video source is standard def 1.33:1, the image will be very small when de-squeezed.
Honestly though, composing with a squeezed image isn’t so bad. You’ll get used to it eventually.
Share this post
Link to post
Thank you for the reply!
the other thing I’m looking and again is there a work around is a 24v battery for my Moviecam sl?
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Ritter Battery
    G-Force Grips
    The Original Slider
    FJS International
    Just Cinema Gear
    Cinematography Books and Gear
