david richardson
How do I power a dedolight DLH4 by battery?
I've heard that they have been used on ships and hard to reach places in little cave. They seem light on battery, but how are they used on the go?
Edited by david richardson
Share this post
Link to post
There are a couple options-
It’s best to run them off high capacity Deep cycle batteries. Camping/UPS batteries work pretty well. A car battery could work at a pinch.
There are a couple different options to do it-
Use and inverter to give you mains AC voltage, and just run the power supply as usual - this is pretty inefficient however.
Directly power them by matching the battery voltage with your lamps (ie 12v lamps in the dedo from a 12v battery or 24v lamps via 2x12v Batteries in series). In this configuration I’ve also previously used a DC motor controller to provide dimming.
Share this post
Link to post
Matthew’s options are perfectly right. If you value a complete “out of the box” solution vs diying cables and batteries (which is not difficult btw), you can get a battery/inverter combo like this..https://www.google.com/amp/s/www.bhphotovideo.com/c/product/1437588-REG/interfit_nom100_nomad_portable_battery_pack.html/amp
One of those nomad batteries will power a dedo for about an hour. So if longevity is needed without having to swap, a deep cycle battery(s) with a much higher w/h rating is needed.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Media Blackout - Custom Cables and AKS
    Just Cinema Gear
    FJS International
    The Original Slider
    G-Force Grips
    Cinematography Books and Gear
