Cale Boys Share Posted November 3, 2020 I'm wanting to use my nucleus-m follow focus system but need to power the gear via a P-tap connector. What option is there for myself to place a small battery onto my shoulder rig? Any suggestions? Quote Link to post Share on other sites
Cale Boys Author Share Posted November 3, 2020 Image of set up: https://imgur.com/a/WtzMpFV Quote Link to post Share on other sites
Baltasar Thomas Share Posted November 4, 2020 If you use the Shape shoulder pad, aren't you able to attach 15mm rods to the back? That would allow for some mounting options to the bottom of the rods. Other options that come to mind are adapting your LTR to take v-mount batteries, or wearing a battery on your belt. The base of your LTR looks modified and huge, what is that? Looks peculiar! It protrudes into the section where your shoulder normally goes. Quote Link to post Share on other sites
Cale Boys Author Share Posted November 4, 2020 9 hours ago, Baltasar Thomas said: If you use the Shape shoulder pad, aren't you able to attach 15mm rods to the back? That would allow for some mounting options to the bottom of the rods. Other options that come to mind are adapting your LTR to take v-mount batteries, or wearing a battery on your belt. The base of your LTR looks modified and huge, what is that? Looks peculiar! It protrudes into the section where your shoulder normally goes. Yeah true, I could put small rods at the back and buy a mini V-lock battery to run the follow focus. The angle the image is taken on makes it look weird, it's just a regular LTR-7 Quote Link to post Share on other sites
