Premium Member Dom Jaeger Posted March 3, 2021 Premium Member Share Posted March 3, 2021 36 minutes ago, Phil Rhodes said: I'd be a bit cautious about creating any system that relies on referring to something as anything other than what it is. We've suffered this already with crop factors on stills cameras, creating a generation of stills photographers who end up going through all sorts of mental arithmetic to express what they mean and risking confusion. Now, was that the actual 50mm we wanted, or the 50mm multiplied by some intermediate factor? There isn't a straightforward way of expressing this stuff without least three bits of information. Most obviously that's the focal length, the squeeze factor if any, and the size of the sensor. You can manipulate numbers and state these in various ways, but in the end, it's always going to be a three term equation. These days, with the proliferation of non-standard sensor sizes and mixing of formats, you also need to know the useable image circle diameter of the lens, which gives you an upper limit on what sensor size (or more accurately what resolution and aspect ratio within the sensor area) you can use. This is one of the issues Greg is facing, mixing a 28mm anamorphic designed for S35 with a 40mm designed for full frame, and why the 40mm ends up having a wider angle of view. The sensor size is a variable dependent on the lens design. I agree that it’s best to keep the system as it is, with lenses simply labelled by focal length and squeeze factor if anamorphic, although I think it would be handy to also have image circle diameters engraved on the barrel as well (I think Sigma cine lenses do this.) In Greg’s case though, it definitely makes sense to have some additional information at hand. Link to comment Share on other sites More sharing options...
Premium Member Gregory Irwin Posted March 10, 2021 Author Premium Member Share Posted March 10, 2021 (edited) What’s crazy to me is, after all the variables are calculated, how wide this anamorphic format ends up on the large format sensor. Pictured are 2 images made with my custom Technovision 1.5x, 50mm Close Focus lens at 19 inches (minimum focus) and 2.5 feet. The aspect ratio is 2.39:1 with a 93% extraction on the Alexa LF. G Edited March 10, 2021 by Gregory Irwin 1 Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted March 10, 2021 Premium Member Share Posted March 10, 2021 If the operator has big ears, they're in shot! Link to comment Share on other sites More sharing options...
Premium Member Satsuki Murashige Posted March 10, 2021 Premium Member Share Posted March 10, 2021 6 hours ago, Gregory Irwin said: What’s crazy to me is, after all the variables are calculated, how wide this anamorphic format ends up on the large format sensor. Pictured are 2 images made with my custom Technovision 1.5x, 50mm Close Focus lens at 19 inches (minimum focus) and 2.5 feet. The aspect ratio is 2.39:1 with a 93% extraction on the Alexa LF. G Does this mean your in-camera pixel aspect ratio will be 1.59:1 before de-squeezing? But you will still be recording the full 1.44:1 open gate? Also very curious to hear about your experience with these lenses - I notice a slight amount of barrel distortion which gives the image a rounded feel to me. Really pulls the eye towards the center of the frame. Seems to be on contrasty side as well, very nice. Link to comment Share on other sites More sharing options...
Premium Member Gregory Irwin Posted March 10, 2021 Author Premium Member Share Posted March 10, 2021 2 hours ago, Satsuki Murashige said: Does this mean your in-camera pixel aspect ratio will be 1.59:1 before de-squeezing? But you will still be recording the full 1.44:1 open gate? Also very curious to hear about your experience with these lenses - I notice a slight amount of barrel distortion which gives the image a rounded feel to me. Really pulls the eye towards the center of the frame. Seems to be on contrasty side as well, very nice. We are definitely recording on the full sensor, 1.44. The only aspect ratio we care about is the 2.39. We don’t really refer to the desqueeze. But you do have a keen eye! The lenses do have a very slight horizontal stretch. But faces are shown to be accurate. No anamorphic mumps. G Link to comment Share on other sites More sharing options...
Premium Member Miguel Angel Posted March 10, 2021 Premium Member Share Posted March 10, 2021 11 hours ago, Gregory Irwin said: What’s crazy to me is, after all the variables are calculated, how wide this anamorphic format ends up on the large format sensor. Pictured are 2 images made with my custom Technovision 1.5x, 50mm Close Focus lens at 19 inches (minimum focus) and 2.5 feet. The aspect ratio is 2.39:1 with a 93% extraction on the Alexa LF. G After watching Lupin on Netflix (which was shot with the lenses you're testing at the moment) they remind me a bit of the Xtal Xpress. Also, the close focus is fantastic, 19 inches! You changed a bit Greg ? 1 Link to comment Share on other sites More sharing options...
Premium Member Satsuki Murashige Posted March 11, 2021 Premium Member Share Posted March 11, 2021 4 hours ago, Gregory Irwin said: We are definitely recording on the full sensor, 1.44. The only aspect ratio we care about is the 2.39. We don’t really refer to the desqueeze. But you do have a keen eye! The lenses do have a very slight horizontal stretch. But faces are shown to be accurate. No anamorphic mumps. G Very cool, thanks for the details Greg. Good luck on the film! 1 Link to comment Share on other sites More sharing options...
Kyryll Sobolev Posted March 16, 2021 Share Posted March 16, 2021 greg, with many different lenses selected for a final package, how do you go about making sure the iris markings/T stop readings are consistent for the DP? i have seen people re-stripe a few lenses which give a different reading than most other ones in the kit... and i'm on a show now where we have atlas orions and panavision T series anamorphics. the T series are consistently darker than atlas, at same T stop reading on the barrel Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted March 17, 2021 Premium Member Share Posted March 17, 2021 9 hours ago, Kyryll Sobolev said: .. i'm on a show now where we have atlas orions and panavision T series anamorphics. the T series are consistently darker than atlas, at same T stop reading on the barrel Presumably you’re renting through Panavision, so have you asked their lens tech about this? Some branches may have a T stop tester, but a tech can also compare luminance readings on an oscilloscope with other lenses set to the same T stop. There can be play in an iris mechanism, or iris cages can sometimes shift especially with motors driving them forcefully into end stops, or an iris drive pin can get bent, or the aperture index ring may have shifted or sometimes manufacturer’s measurement processes and quality control can vary. Link to comment Share on other sites More sharing options...
Kyryll Sobolev Posted March 17, 2021 Share Posted March 17, 2021 yes pana here has that T stop reading device, and i have seen the tech here restripe lenses with tape and marker i should rephrase my question to more organizational aspect - if you have many various lenses, do you select some to act as "base" lenses, and match others to them (if the lenses actually do give different readings) Link to comment Share on other sites More sharing options...
Premium Member Gregory Irwin Posted March 17, 2021 Author Premium Member Share Posted March 17, 2021 3 hours ago, Kyryll Sobolev said: yes pana here has that T stop reading device, and i have seen the tech here restripe lenses with tape and marker i should rephrase my question to more organizational aspect - if you have many various lenses, do you select some to act as "base" lenses, and match others to them (if the lenses actually do give different readings) In my experience, we don’t restripe lenses. Most of the variations are slight and we can instantly see them on a calibrated monitor and compensate if necessary. There are so many other variables that can also affect exposure, you can drive yourself crazy. Keep it stupid simple. G Link to comment Share on other sites More sharing options...
Shawn Martin Posted May 2, 2021 Share Posted May 2, 2021 How's the shoot going so far, Greg? Curious to hear what lenses you ended up choosing to complete your set! Link to comment Share on other sites More sharing options...
Premium Member Gregory Irwin Posted May 3, 2021 Author Premium Member Share Posted May 3, 2021 (edited) 22 hours ago, Shawn Martin said: How's the shoot going so far, Greg? Curious to hear what lenses you ended up choosing to complete your set! The show is going very well. I’ve attached my cheat sheet of the main unit lens package for you to see. G Edited May 3, 2021 by Gregory Irwin Link to comment Share on other sites More sharing options...
Shawn Martin Posted May 3, 2021 Share Posted May 3, 2021 That's a ton of lenses! Thanks a lot for that info. Are there any there besides the new Technovision ones that you haven't used before? Link to comment Share on other sites More sharing options...
Premium Member Gregory Irwin Posted May 3, 2021 Author Premium Member Share Posted May 3, 2021 1 hour ago, Shawn Martin said: That's a ton of lenses! Thanks a lot for that info. Are there any there besides the new Technovision ones that you haven't used before? No. The Technos are the only new lenses to us. We’ve used all of the others many times over the years. G Link to comment Share on other sites More sharing options...
Shawn Martin Posted May 4, 2021 Share Posted May 4, 2021 Gotcha - glad the shoot is going well! Link to comment Share on other sites More sharing options...
Premium Member Miguel Angel Posted January 26, 2022 Premium Member Share Posted January 26, 2022 @Gregory Irwin just wanted to chime in to say that I shot a commercial last Friday with the Technovision lenses and your lens sheet was very handy!! ? Link to comment Share on other sites More sharing options...
Premium Member Gregory Irwin Posted January 27, 2022 Author Premium Member Share Posted January 27, 2022 On 1/26/2022 at 5:35 AM, Miguel Angel said: @Gregory Irwin just wanted to chime in to say that I shot a commercial last Friday with the Technovision lenses and your lens sheet was very handy!! ? That’s great Miguel! I’m so glad that was useful. Thank you for letting me know! What did you think about the lenses? G Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted January 27, 2022 Premium Member Share Posted January 27, 2022 On 5/3/2021 at 2:42 PM, Gregory Irwin said: The show is going very well. I’ve attached my cheat sheet of the main unit lens package for you to see. G So you dropped the idea of listing their AOV? Link to comment Share on other sites More sharing options...
Premium Member Gregory Irwin Posted January 28, 2022 Author Premium Member Share Posted January 28, 2022 6 hours ago, David Mullen ASC said: So you dropped the idea of listing their AOV? Absolutely not! The AOV was included in my lens tech data sheets that were provided to the relevant on set personnel, VFX, post and editorial. I just wanted our everyday cheat sheet to be more consolidated and concise. The one pictured was attached to my lanyard that had my ID and studio gate pass on it that I wear around my neck everyday. G 1 Link to comment Share on other sites More sharing options...
Premium Member Miguel Angel Posted January 28, 2022 Premium Member Share Posted January 28, 2022 17 hours ago, Gregory Irwin said: That’s great Miguel! I’m so glad that was useful. Thank you for letting me know! What did you think about the lenses? G Even though I don't really like anamorphic anymore I think that the Technos are quite good AND BIG but they are super lightweight for hand-held!! They don't feel sharp and they resolve faces pretty well, especially because I think that the 40mm and the 50mm do a great job at focusing your attention at the center of the lens. The 75mm was my favourite (we had the 40, 50 and 75). I loved the close focus on the 40mm and the 50mm! I wish they weren't that contrasty overall and looked a bit more like the Xtal Xpress. I had a Black Diffusion FX 1 all the time on them and shot at 10.000asa on the Venice underexposing 1 1/2 stop as well so maybe I shouldn't judge them based on this project ? Perhaps Ps+technik could develop a diopter to put at the back of the lenses to detune them or take the coat off them to make them a tad softer. These are some screengrabs from yesterday's colour grading session where our colourist put a lot of grain in it (90% of the commercial is archive material so we had to kind of match the feeling of what we shot to that) We used the Technos for 2 sequences (bar and van) and the Supremes for another 2 (office and supermarket) It is all available and natural light modified with a clrs frame or a 2 meters x 2 meters frame. These below are the Supremes Link to comment Share on other sites More sharing options...
Premium Member Gregory Irwin Posted January 30, 2022 Author Premium Member Share Posted January 30, 2022 (edited) On 1/28/2022 at 5:13 AM, Miguel Angel said: Even though I don't really like anamorphic anymore I think that the Technos are quite good AND BIG but they are super lightweight for hand-held!! They don't feel sharp and they resolve faces pretty well, especially because I think that the 40mm and the 50mm do a great job at focusing your attention at the center of the lens. The 75mm was my favourite (we had the 40, 50 and 75). I loved the close focus on the 40mm and the 50mm! I wish they weren't that contrasty overall and looked a bit more like the Xtal Xpress. I had a Black Diffusion FX 1 all the time on them and shot at 10.000asa on the Venice underexposing 1 1/2 stop as well so maybe I shouldn't judge them based on this project ? Perhaps Ps+technik could develop a diopter to put at the back of the lenses to detune them or take the coat off them to make them a tad softer. These are some screengrabs from yesterday's colour grading session where our colourist put a lot of grain in it (90% of the commercial is archive material so we had to kind of match the feeling of what we shot to that) We used the Technos for 2 sequences (bar and van) and the Supremes for another 2 (office and supermarket) It is all available and natural light modified with a clrs frame or a 2 meters x 2 meters frame. These below are the Supremes Beautiful work Miguel! I love how the Techno’s focus falls off gently to a nice shallow depth. Did you have the close focus version of the 40, 50 and 75mm? They are brilliant! The only thing I wish I could do with them, like I do with all of my Panavision Anamorphics, is weigh the focus strength to the 1/3rd sides of frame away from the center. That’s where we frame things anamorphically. I’m actually working with P&S to improve future generations of the lenses, including lens data. Keep up the great work Miguel! G Edited January 30, 2022 by Gregory Irwin Link to comment Share on other sites More sharing options...
