Ben Kahn Share Posted April 4 Hi, I'm shooting an old CRT TV, playing a video from a VCR. I'll be using the Sony Venice. I did a test with a Sony mirrorless and couldn't get rid of the rolling bars no matter what shutter I tried. I'm assuming it will have the same result with the Venice. I know sync boxes are used for film cameras. Do they work for digital cameras as well? Or is there another solution. Thanks for the help. Ben Quote Link to post Share on other sites
Max Field Share Posted April 5 Is the Venice a global shutter? It's weird cause I was shooting a CRT TV with a 5D and was trying to get the scanlines to show up and it was kinda tricky lol. Quote Link to post Share on other sites
Satsuki Murashige Sustaining Member Share Posted April 5 The Venice is a rolling shutter camera. Ben, on the Venice you should be able to use Synchro Scan to adjust the shutter angle or shutter speed in minute increments. Start with 1/60 sec (or 144.00 degree angle with 24fps) and adjust from there. Quote Link to post Share on other sites
Giray Izcan Share Posted Monday at 04:32 AM (edited) There is a device called tv sync box but I am not sure if you could use it with digital cameras. It was by Cinematagraphy Electronics. I suppose you could get one and take/send it to Andre for him to change the plug to whatever you want and then test. It should cost around 250-400 nowadays... Edited Monday at 04:33 AM by Giray Izcan Quote Link to post Share on other sites
Stephen Sanchez Sustaining Member Share Posted Wednesday at 12:11 AM @Ben Kahn, in the Shutter menu, you should have 3 options: Shutter Speed, Shutter Angle, and ECS Mode. ECS mode will allow you to scroll through the frequency in .1 increments. You can find your balance that way. I know this option is on Sony FX7 and FX9. The Venice should have the same mode. Keep in mind that an excessive change from say 58 to 93.2 translates the same in light loss, as you're simply manually controlling the cycle rate of the shutter. Quote Link to post Share on other sites
Ben Kahn Author Share Posted Wednesday at 12:45 AM 33 minutes ago, Stephen Sanchez said: @Ben Kahn, in the Shutter menu, you should have 3 options: Shutter Speed, Shutter Angle, and ECS Mode. ECS mode will allow you to scroll through the frequency in .1 increments. You can find your balance that way. I know this option is on Sony FX7 and FX9. The Venice should have the same mode. Keep in mind that an excessive change from say 58 to 93.2 translates the same in light loss, as you're simply manually controlling the cycle rate of the shutter. Thanks Stephen! I'll try this Quote Link to post Share on other sites
Max Moosbrugger Share Posted Wednesday at 01:26 AM iAs far as rolling shutters go the Venice is on par with an Alexa from what I've heard. I can't say for certain it will perform adequate for your needs, it will definitely make any dslr or mirrorless camera look like shite. However the Venice has been out for a few years now, so most likely someone somewhere was in a similar situation, best advice I can give is researching statements from people experienced with the Venice. I can't imagine that there aren't any operators that have shot the venice with a CRT monitor in the background somewhere, but what would I know, I can't say that I've shot on a Sony camera Quote Link to post Share on other sites
Robin R Probyn Share Posted Friday at 10:11 AM (edited) On 4/7/2021 at 9:45 AM, Ben Kahn said: Thanks Stephen! I'll try this https://www.sony.net/Products/Cinematography/Venice/ Top right Hot button of the LCD screen , set to Cont (continuous ) from Step .. + / - buttons Edited Friday at 10:19 AM by Robin R Probyn Quote Link to post Share on other sites
