Controlling a book light
So I have started experimenting with the book lighting technique. The light quality is beautiful how it lands on talent however I find that it spills everywhere including the walls. I have used flags but have not had the type of result that I want. Is there something I am missing in terms of controlling the spill?
Link to post
10 hours ago, omar robles said:
Thanks everyone
If its just for something like interviews / closer shots, the far easier way is to use a large soft box ,with a grid , on your light ..they will really work to control spill with minimum effort and gear.. a book light is not intrinsically making the light softer , its just evening out the spread of light from the source ,hitting the diffusion  .. soft box with an internal baffle will do the same with a much easier set up .. the actual  "softness "  is based on the size of the source to the object , nothing else ..
  • Upvote 1
Link to post
If you want to control and shape your light, a book light is a pretty poor choice of source. They're basically the most diffuse and omni-directional of all lights.
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
