Decent Tripod for dSLR
M Joel W
I'm getting back into shooting smaller projects with my Panasonic S1. I'd like a tripod with a fluid head that's inexpensive and small and balances with a 3lb camera. Any recommendations? I know this site isn't tailored toward consumer equipment, but I figure people here have high standards. Which unfortunately after operating an O'Connor head even once so do I. ? But it just has to be decent.
Cheap and compact would be nice. I will also use this with a friend’s C100 and plan to travel with it between coasts. Or I could just rent but recommendations there would be nice, too. Manfrotto? Sachtler Ace?
Edited by M Joel W
Link to comment
As cheap as possible, a few hundred dollars. I don't mind renting or buying used if there's nothing decent and affordable. It doesn't have to be great but I am a bit spoiled now so I'd probably rather rent something good than own something bad.
Edit: I'm not that spoiled, though. Decent is fine.
Edited by M Joel W
Link to comment
Nothing is going to feel like an OConnor 2575 head except... an OConnor. Even my Sachtler Cine30 HD is a step down (half the weight for a similar payload, though).
For a few hundred bucks, I’d consider the Benro S6 Pro with a flat base on some photo legs. At least it has the tilt lock on the operator side, unlike a Manfrotto 502. Have not tried the 504X. Never been a fan of Manfrotto.
If you can go $500+, the Cartoni Focus 8, Miller DS-10 are decent options.
Above $1000 USD, I’d go with a used Sachtler, Vinten, Miller (or OConnor naturally).
Link to comment
Not enough money for a decent fluid head. Rent.
Save up and buy a decent one when you can; it's a lifetime purchase. These days you can get types with finely or infinitely variable spring balance which handle everything. I have a Sachtler Aktiv8 head and Flowtech tripod here on review right now - it's also sold under the Vinten brand - and I suspect it'd be all most people need.
Though frankly the Vinten Vision 3 I bought in 2001, which wasn't new then, would also be all most people need. Do it once, do it right, never think about it again.
Link to comment
Thanks. I had an old Vinten I sold for next to nothing and regret selling, it was good.
This is the type of thing I plan to shoot with like a crew of three so really anything would be good enough but I think I'll just rent a Sachtler Ace for a few days or the other option is a Benro S8, which is probably what I'll go with. For what I'm working on, that is good enough.
Link to comment
A bit off topic, but Phil do you know if the Aktiv10 will get a Touch and Go plate version?
I need to replace my Cartoni Focus F101 100mm head and I do not like side-load plates (except on beefy OConnor/Sachtler heads). Already have 100mm Miller Solo legs that I would like to keep using.
Link to comment
