imran qureshi Posted July 21, 2021 Share Posted July 21, 2021 850ISO is the base iso on my camera where I get the most dynamic range. The issue is that my light meter only has 800 ISO and not 850 ISO. I can use the exposure compensation on my light meter (i can adjust by 1/10th of a stop at a time) to try and sort this (I hope) but I am not quite sure how to work that out, Wondering if anybody could help me sort this issue out? Thanks! Link to comment Share on other sites More sharing options...
M Joel W Posted July 21, 2021 Share Posted July 21, 2021 (edited) When I had a C100 I just rated it at 800 ISO. I was mostly using still lenses then though so I figured the t-stop f-stop difference was darkening the image more than the extra 50 ISO was brightening it. I notice when people shoot by eye on the C300 etc. they tend to overexpose (or maybe not I dunno) so I think overexposing a bit is fine. Edited July 21, 2021 by M Joel W Link to comment Share on other sites More sharing options...
imran qureshi Posted July 21, 2021 Author Share Posted July 21, 2021 6 minutes ago, M Joel W said: When I had a C100 I just rated it at 800 ISO. Do you mean you shot at 800 iso or do you mean you shot at 850 and metered it at 800? Cheers Link to comment Share on other sites More sharing options...
M Joel W Posted July 21, 2021 Share Posted July 21, 2021 Shot at 850 and metered at 800. The 850 ISO setting always seemed a little "off" to me. With the internal codec, shadows sometimes got blocky, and it was safer to overexpose than underexpose. And that is such a trivial difference anyway. I suspect most people using these cameras are overexposing more often than not. There's a whole school of thought (ETTR) that encourages it, but I don't buy into that. On the other hand, I used to rate the F5 around 800 ISO or 1250 ISO instead of 2000 ISO too. Link to comment Share on other sites More sharing options...
imran qureshi Posted July 21, 2021 Author Share Posted July 21, 2021 (edited) 16 minutes ago, M Joel W said: Shot at 850 and metered at 800. The 850 ISO setting always seemed a little "off" to me. With the internal codec, shadows sometimes got blocky, and it was safer to overexpose than underexpose. And that is such a trivial difference anyway. I suspect most people using these cameras are overexposing more often than not. There's a whole school of thought (ETTR) that encourages it, but I don't buy into that. On the other hand, I used to rate the F5 around 800 ISO or 1250 ISO instead of 2000 ISO too. Thanks! Its interesting because I am wanting to expose to the right as I feel its useful for my c100 (its a camera that likes a lot of light) but first I just want to ‘calibrate my meter to my camera’ (make sure my meter’s middle grey and canons recommended ire for middle grey in Clog’ is the same). I guess i dont really need to know how to compensate for 50iso, i can just meter it at 800 and just use exposure compensation till the meter gives me what I want. I just thought it might be something useful to learn though and cant find much info on it online! Edited July 21, 2021 by imran qureshi Link to comment Share on other sites More sharing options...
M Joel W Posted July 21, 2021 Share Posted July 21, 2021 (edited) If I'm not mistaken 850 ISO is almost exactly 1/10th of a stop faster than 800 ISO. 857 ISO? But I just rated my camera at 800 ISO. ? So if you want to do things right my guess would be to correct by 1/10th of a stop. But in my experience the camera doesn't love underexposure and most photo lenses are slower than their stated f-stop so I just set my meter to 800 ISO and went with it. ? Edit: I don't really believe in ETTR but I do believe in slightly overexposing some cameras. I dunno, I don't shoot much anymore. I think you can find online where different cameras put middle gray and different log profiles place it quite differently. I really like the Canon Log image from the C100 a lot but do find the codec a bit thin in the shadows sometimes. Edited July 21, 2021 by M Joel W Link to comment Share on other sites More sharing options...
imran qureshi Posted July 21, 2021 Author Share Posted July 21, 2021 41 minutes ago, M Joel W said: If I'm not mistaken 850 ISO is almost exactly 1/10th of a stop faster than 800 ISO. 857 ISO? But I just rated my camera at 800 ISO. ? So if you want to do things right my guess would be to correct by 1/10th of a stop. But in my experience the camera doesn't love underexposure and most photo lenses are slower than their stated f-stop so I just set my meter to 800 ISO and went with it. ? Edit: I don't really believe in ETTR but I do believe in slightly overexposing some cameras. I dunno, I don't shoot much anymore. I think you can find online where different cameras put middle gray and different log profiles place it quite differently. I really like the Canon Log image from the C100 a lot but do find the codec a bit thin in the shadows sometimes. Ahh if it is 1/10th of a stop faster that is my answer! Thanks Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted July 22, 2021 Premium Member Share Posted July 22, 2021 A difference of 50 ISO (ASA) doesn't actually mean anything without a reference point. 50 ISO to 100 ISO for example is a whole stop difference, while 800 ISO to 850 ISO is a small fraction of a stop ( I calculate it to be 0.87 of a stop - so even less than a tenth). Here's a graph of ISO/ASA numbers showing third stop increments, which are normally the only ISO settings available in digital cameras: I'm surprised Canon chose to have an non-standard ISO 850 setting in the C100, given how close it is to 800. Does it really make any difference to the DR? A tenth of a stop would be less than the assembly tolerance of even high end cine lens aperture scales, and many lenses would have more play than that just in the aperture mechanism. Link to comment Share on other sites More sharing options...
M Joel W Posted July 22, 2021 Share Posted July 22, 2021 (edited) 44 minutes ago, Dom Jaeger said: A difference of 50 ISO (ASA) doesn't actually mean anything without a reference point. 50 ISO to 100 ISO for example is a whole stop difference, while 800 ISO to 850 ISO is a small fraction of a stop ( I calculate it to be 0.87 of a stop - so even less than a tenth). Here's a graph of ISO/ASA numbers showing third stop increments, which are normally the only ISO settings available in digital cameras: I'm surprised Canon chose to have an non-standard ISO 850 setting in the C100, given how close it is to 800. Does it really make any difference to the DR? A tenth of a stop would be less than the assembly tolerance of even high end cine lens aperture scales, and many lenses would have more play than that just in the aperture mechanism. I get .087 stops too but rounded up to .1. As I mentioned, I just rated at 800 ISO. Maybe it was something to do with fudging the over/under. Or just where something landed? I believe the camera has 800 ISO as an option, too, but 850 is considered native. Anyway, it's a nice camera! Edited July 22, 2021 by M Joel W Link to comment Share on other sites More sharing options...
