Hello!
I am trying to get 12V out of my Arri SR2 HS from 11 pin Fischer connector at the back for the accessory, but when I measured the voltage it appears to be only 2,5V :(.
For the pinout I found a scan from Jon Fauer "Arriflex SR book" scanned and uploaded in the other topic on this forum.
(Original topic with the scheme here:)
What is even stranger, the voltage slightly changes, and can even go to zero when I turn the potentiometer knob on a "GLOW" that is on the side of my camera - also pictures attached:
111aaaa1arrisr2222.thumb.jpg.3334c71e61c04bbec8ff353c59118455.jpg1111arrisr1222.thumb.jpg.aa6047bebac8f2d2a404f96e4f87f2e1.jpg
Do you have any ideas what could be causing the problem? When I unplug the two wires that power the GLOW, camera will not run.
I will appreciate any ideas!
Thank you!
Adrian
