How bright do I need my LED tube practicals to be?
Viggo Söderberg
 Share
I'm going to be lighting a bathroom scene with LED tubes over the bathroom mirrors. I will be buying these practicals but I don't know how to make sure I'll be getting enough light for them. The coolest tubes I could find was 4000K. I want them to give off a cyan look so I will be white balancing at around 4000K, then I will be gelling these practicals with a 1/2 CTB and a Half Plus Green. (I'll also be using some orange practicals so that's why I'm not white balancing at 3200K) Now seeing as I'm gelling these tubes with two layers I'm unsure I'll be getting a lot of light. 1/2 CTB has a transmission of 52% I think, and Half Plus Green has a transmission of 82%. I want the bathroom to be pretty dark but these fixtures will be the keylight. Not sure what stop I'll be using but possible I'll be around 2.8 so that I'm getting enough light. I don't know enough about lumens to know how to calculate how strong I need these lights to be (keeping the loss of light from the gels in mind). Could I have a hand working that out maybe?
Link to comment
  • Sustaining Member
What ISO and T-stop will you be shooting at?
Usually, I’ve found you don’t need much output from tube lights if you’re placing them so close to the subject. Also, if you want the color to be saturated, then you don’t want them too bright or they’ll look more desaturated.
If the bathroom tiles are shiny, that will help amplify the light output as well.
  • Upvote 2
Link to comment
Think I'll be shooting at 800 ISO at 2.8. Alexa Mini with Zeiss CP.2.
Link to comment
  • Sustaining Member
3 minutes ago, Viggo Söderberg said:
With any strength of the light? I was wondering what lumen value I should be looking for.
The old standard formula for exposure is: 100ISO @ f/2.8 = 100fc (footcandles).
1 footcandle = 1 lumen/sq ft.
https://www.standardpro.com/how-to-measure-light/
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
Forum Sponsors
Film Gears
DMX-iT
FJS International
Cinematography Books and Gear
