Premium Member William Robinson Posted March 14 Premium Member Share Posted March 14 For Sale: Brand new, never been used 4x5 Rota Pola with a 15mm rod support allowing you to mount a motor to wirelessly control the Pola with your Lens Control system. This True Color Rotating Pola by NiSi is the most elegant way to control the Pola settings from your handset. No more struggling off the bottom rods or using a long unstable rod of the top. This is a must have for cranes, steadi cams and Russian Arm work. This item works perfectly with the Arri Cforce mini motor! Mounted PL Polarizing Filter Rotatable, Optical Glass M0.8 focus control gear, allowing adjustments with an attached small motor or manually 6mm-Thick, Aluminum-Alloy Filter Tray +1 to 1.5 Stops Helps to Eliminate Reflections and Glare Reduces Haze True Color technology removes the warm tone seen with other brands of polarizing filters Padded Pouch Asking $300.00 Bill 323-683-3145 Link to comment Share on other sites More sharing options...
