Premium Member Stephen Lee Clements Posted January 15, 2025 Premium Member Posted January 15, 2025 I have two vintage Angenieux lenses that I would like to sell. Ideally the whole package, but individually is acceptable (see pricing below.) Both for sure cover Super35, and some focal lengths can cover larger sensors. Links in the comments to projects that have been shot with these, as well as further images. The first is an Angenieux 20-120mm T2.9 (6x zoom) with a universal submount. Currently there's a PL mount on there, and I will include the original Arri bayonet mount and a PL adapter for that. I have added a couple of parts to create a top-rail solution like more modern zoom lenses have. Per Angenieux, the serial number puts it somewhere in the 1970s, so I believe it's missing some coatings that those modern lenses also have, but this creates an incredible character. This lens is often paired with Cooke primes as a package. The second is an Angenieux 25-250mm T3.2 (10x zoom) with a universal submount. Currently there is an Arri bayonet mount, and I have a small PL mount that will work with it. I have not had a chance to make the same top-rail solution. Per Angenieux, the serial number comes from the late '60s or early '70s. The character of this lens is not as strong as the 6x, but the extra 130mm on the zoom makes it a good secondary zoom for the package. Both lenses have been well taken care of, and have not been used much in the last five years. They were serviced by Duclos Lenses when I first got them, and are still in good working order. The accessories I have are mostly pictured, and include: Arri Studio 15mm baseplate & rails, Arri FF-2 focus with second wheel and "transmission" block, a "fat" wheel for the focus (these lenses both trombone in and out when focusing,) and a lens support SmallRig EVF mount, 15mm studio adapter with a NATO rail, rear handle extensions, monitor mount with Arri pins, and various threading adapters There are two handmade camera risers for the baseplate: a Canon C300/C100 size mount, and a RED Epic/Weapon mount Shoulder mount handle setup 3D-printed shade for 6x, original shade for 10x, Series 9 stacking adapter rings for 10x, and three Series 9 85ND filters (will require white balance adjustments on digital cameras) Case with foam cutout for entire kit Pricing is as follows: Entire kit: $10,000 OR 6x with top handle, PL & bayonet submount, and specific accessories: $6,000 10x with case and all other accessories: $5,000 Email steadiclements@gmail or message me here (though I can't be sure I'll see it quickly.)
Premium Member Stephen Lee Clements Posted January 15, 2025 Author Premium Member Posted January 15, 2025 Additional pieces of kit. The two aluminum pieces are handmade adapters for the Arri baseplate system, one for a C100/C300 body, and one for RED Epic size.
Premium Member Stephen Lee Clements Posted January 15, 2025 Author Premium Member Posted January 15, 2025 Additional pieces included in kit. Series 9 and other filters will work for 10x. Bottom-center in the first image is the 3D printed shade for the 6x.
Premium Member Stephen Lee Clements Posted January 15, 2025 Author Premium Member Posted January 15, 2025 Two pictures of the 6x set up and in use with a C100 Mark II. At this link is a webseries I shot, predominantly with the 6x, and with four or five different camera bodies:
Premium Member Stephen Lee Clements Posted May 18, 2025 Author Premium Member Posted May 18, 2025 Price drop: $8000 for both, $5000 for the 6x, $4000 for the 10x & accessories.
