Ultimate Bolex EBM Super 16 Production Package
Guest gregorscheer
Ultimate Bolex EBM Super 16 Production Package US $ 4250 or best bid
Converted to super 16 and newly lubricated and serviced by Aranda Design in Melbourne www.design.arandafilm.com.au Film tested, camera is in excellent cosmetic and working condition. I am selling this package because I have two similar kits and it turns out that I do not take both of them when I travel to make our Films. You can check our production of educational documentaries on www.vinestreetworks.com you can also mail us with any questions you might have at gregor@vinestreetworks.com or phone us at +1 718 524 0221. If you are in New York we will be pleased to show you the camera and some of the film the camera is capable to produce.
This is the ultimate kit for Super 16 mm film sync sound production. Blow up to 35mm for theatrical distribution or telecine to High Definition Video for broadcast, this complete camera package is ready for high quality professional and indy film production on the economic 16mm budget
Features of the Bolex H- 16 EBM:
Electrically driven,Electronically stabilized motor drive, 10, 18, 24, 25 and 50fps. backwind possible, 170º shutter Bolex bayonet mount, auto film loading (for 100ft loads), Accepts 400 magazine (2 included).Basic EBM camera accepts single or double perforated 100' film rolls: magazine and take - up motor (included)permit use of 200' daylight - load rolls or 400' film cores. 1:1 drive shaft, flat base. The camera can by synced for sound (at 24 or 25fps) with the included switchable crystal lock. also permits cord connected sound with accessory sync-pulse generator.
built - in automatic slating system eliminates separate 'clapstick' when filming with sync - pulse unit (not included). The camera can be handheld with the battery in the power grip or it can be mounted on a tripod with an external battery. Precision film registration. Assures genuinely excellent steadiness and frame registration, particularly important when film rewound for special - effects applications and in blow-ups to 35 mm format. Brilliant reflex finder shows image recorded by film at 14X magnification;
matte ground glass surface assures critically accurate focusing. Image is free of flicker and remains visible at all times. Automatic film threading. Unique Bolex mechanism threads film through gate for faster, simpler film interchange even in brilliant light. loop formers retract automatically when camera door is closed. Loop restored instantly if lost while filming.Automatic spool ejector simplifies unloading.
Features of the 16-100mm f1.9 POE lens:
This is a very sharp wide range zoom that has a very fast maximum aperture of f1.9 all the way through its range. The lens has a built in light meter so you can use it as a fully auto iris lens if required, it can be used in full manual mode too. The lens has a power zoom function, or can be zoomed manually. The light meter on the, this is the later version which goes up to 400ASA.
The lens requires 3 x PX1 batteries (included) to drive the auto iris and power zoom. This lens covers the super-16 format very well.
Batteries:
The original batteries for this camera were Ni-Cad and these types of batteries are heavy with fairly short life expectancy and they would need to be discharged before recharging otherwise the battery cells would lose capacity. We are supplying a new Nickel Metal Hydride battery which does not need to be discharged before recharging. These batteries are also lighter in weight and are double the capacity of the original.
This camera is supplied with:
power grip with quick release, battery charger with an internal and an external battery, switchable crystal sync lock 24/25fps, body cap, Switar 16-100mm f1.9 POE lens the all necessary cables and connectors for handheld and tripod operation, internal and external batteries, 110/220 volt Bolex charger and copies of instruction manuals for camera, magazines, filter holders and C mount adapter in a solid flight case.
The kit includes:
1 x Bolex H-16 EBM 16mm camera body converted to super 16 complete with body caps and magazine cap.
1 x Vario-Switar 16-100mm f1.9 POE lens, bayonet mount complete with front and back caps
2 x Bolex 400ft magazines converted to super 16 complete with cores and bobbins
1 x Bolex MM magazine torque motor
1 x Bolex 'Ponal' power handgrip
1 x external battery 12 volt
1 x battery power cable with remote on/off
1 x 12v 2ah Nickel Metal Hydride rechargeable camera battery
1 x switchable Bolex Charger 110V/220V
3 x PX1 batteries for the lens (new)
1 x Bolex 'Adsim' adaptor to use C-mount lenses on the EBM camera
2 x Internal camera magazine rollers
2 x Bolex filter keys
1 x Rubber eyecup
1 x 100ft take up spool
1 x solid fitted flight case
1 x User guide (copy) for H-16 EBM
1 x User guide (copy) for 400ft magazine
1 x User guide (copy) for Switar 16-100mm f1.9 lens
