Fireworks
joanna
hi from sunny Australia!!!
what colour temperature do you guys find gives the most accurate colour rendition of night-time fireworks?
would a stop of shutter (1/60) make much difference visually? i realise this would also soak up a stop of light.
i'm using Sony Betacam SX.
thanks....
Link to comment
I was actually playing around with this on New Years and found that daylight (5600K) looks best. With 3200K, white fireworks turn blue-ish.
I'm not too clear on what you mean by "stop of shutter," but I simply used "no shutter" (1/60th) as my speed. It looked pretty good. Of course, if you are staying in 60i, using shutter speeds faster than 1/60th won't produce that noticeable visual changes.
Link to comment
Hi Joanna,
I have shot fireworks quite a few times and I feel Alvin has good advice with shooting under the daylight setting. Any ambient outdoor lights will be a little warmer as well which can be a nice effect. If you have the ability to shoot at a shutter speed slower than 1/60, you may want to experiment. Slowing the shutter may eliminate potential underexposure as well as giving some interesting trailing effects. Good luck.
Jim
Link to comment
That makes sense since firework create white light by burning phosphors, which burn extreamly white, not sure what the color temp is but obviously must be in the 5600k range. My question is, since arial flares (like battle field lighting flares) are basically fireworks using the same technology, would this also hold true for them.
Link to comment
The color of a flare depends on its chemical composition. I suspect many use magnesium, and so would be quite high in color temperature.
Here are some links:
http://www.pbs.org/wgbh/nova/fireworks/anat_nf.html
http://hmchemdemo.clt.binghamton.edu/zumda...07fireworks.htm
http://www.skylighter.com/mall/chemicals.asp?Sort=S
http://www.pyro-pages.com/Info/Chemistry/chemical.htm
Be careful!
Link to comment
