HI,
I just filmed an exterior night and had to mix diferent negatives because of budget. For master shots I used kodak 500T and for close up or tighter frames I used 200T. In the master shots I have some dark areas and I may push the film 1/2 a stop but I am not sure if the look between master and close shots will be to great after pushing the film, and there is one close up done withh 500T.
I may push the film because I used a F2.0 2/3 stop and mi brightest area was 4.0 and my lowest are was 1.0 reflected readings.
Any suggestions would be great.
Miguel
"Pushing" the 200T will generally increase the contrast and graininess. Probably a better match for 7279, but may actually look more grainy than 7218.
