Sorry, Yes, you need to be corrected here.
Red shoots at s35, s16 and 2/3 sensorsize. So you can actually use the formats you want.
The sensorsize can be selected. s16 is 2k, 2/3 1080p and s35k 4k and 2540p.
However, regarding the S:I. camera - it think its a great product.
And, as i am owning sony hdcam, old arri 35mm and have red on order, i think its interesting to know that i am considering to buy a SI.
Especially the mini is really interesting.
That said, i think there are other unique strenghts in the SI concept.
The integration of Iridias Speedgrade and Aspect Ration are excellent feature.
Also the 72fps overcranking is a great feature.
Once again you posted when you didn't need to. I try not to read your responses but I screw up sometimes. You didn't correct anything. Yes, I know the sensor can be windowed, I hinted at that at the bottom of the post when I mentioned many would probably shoot with S16 glass. I used the 35mm sensor example above to try to make a DOF point, which I did. I think you are fitting into the fan-boy status here. Not sure why you feel you have to get in on every post where you think you can *try* to make a point. Be a little more choosey when posting.
