18 FPS VS. 24FPS
learjet76
What can I expect quality wise, if I use 18 FPS VS. 24 FPS
In terms of exposure, DOF, etc. it won't change much. The biggest consideration is whether you plan to blow this up for projection in a larger format, or telecine it. In those cases, 24 has a big advantage over the oddball 18, which is only supported by S-8 projection. Step printing up from 18 to 24, 25, or 30 will give you jerky motion.
Link to comment
Worldwide, theatres normally project sound films at at 24fps.
25fps is sometimes used for television productions intended for 50Hz television systems (e.g., PAL).
30fps (29.97) is sometimes used for productions intended for 60Hz television systems (e.g., NTSC).
18fps home movies are just that.
Link to comment
  • 1 month later...
What about for the purposes of making a short to be transfered/edited miniDV and projected from a DVD? I'm considering shooting 18fps due to my miniscule budget.
-steve
Link to comment
