Premium Member John Sprung Posted February 26, 2007 Premium Member Share Posted February 26, 2007 The Russian MosKinAp 1-KCP-8M dates from 1997, and was loaned out to my ex gaffer for a long time. Probably ran no more than a few thousand feet. The bad thing about this one is that one part in the viewfinder assembly appears to have had a manufacturing defect that caused it to corrode under the paint. The kit includes 2 - 400 ft. mags, 3 - 200 ft. mags, the stovepipe finder extension for tripod use, and these lenses: 18 mm f/2.5 35 mm f/2.3 50 mm f/2.3 75 mm f/2.3 150 mm f/3.1 300 mm f/3.5 The Eyemo appears to be a WWII Air Force recon unit. It shoots one frame at a time, like an animation camera. But it comes with a second movement assembly that I believe is for continuous motion. It has a 50 mm lens, and appears to work mechanically, though I haven't shot with it. The Bardwell & McAlister 2k Junior is a big fresnel type. It comes with the original three riser stand, barn doors, snoot, lots of scrims and gel rings, and at least one quartz lamp. (There should also be a tungsten one, but I haven't found it yet.) So, make an offer, help make some room in my garage -- You can call me at 818 655-7423. Thanks -- -- J.S. Link to comment Share on other sites More sharing options...
