Premium Member John Sprung Posted April 29, 2008 Premium Member Share Posted April 29, 2008 Most C-mount lenses are designed for 2/3" not 1". Actually, most C-mount lenses were designed for regular 16mm film, which is larger than 2/3" video. The camera aperture is 0.404" x 0.295". They're also designed to make an image directly on the film rather than through a prism block. Edit: Figuring out from your numbers for 1" video, I get 0.559" x 0.315", so probably most C lenses won't make a big enough image. Nikon F mount lenses will cover, but may be too far the other way. They make such a big image that wide angles will be a problem. -- J.S. Link to comment Share on other sites More sharing options...
Premium Member John Sprung Posted April 29, 2008 Premium Member Share Posted April 29, 2008 The 1" CCD is a marketing term, as the sensor is bigger than 2/3" but less than a 1" but "close" enough. Actually, all these nominal video dimensions come not from marketing, but from history. Back in the tube camera days, 1" or 2/3", etc, were the actual outside diameters of the tubes. The images, of course, had to be smaller than that. -- J.S. Link to comment Share on other sites More sharing options...
Guest Glen Alexander Posted April 29, 2008 Share Posted April 29, 2008 Actually, all these nominal video dimensions come not from marketing, but from history. Back in the tube camera days, 1" or 2/3", etc, were the actual outside diameters of the tubes. The images, of course, had to be smaller than that. -- J.S. Way off topic, but mentioning good old tubes. I had a set of Klipsch Cornwall II's and Heresy II's that sounded so much better with a good set of 10W tubes than a modern 150W Yamaha Receiver with Dolby, DTS,THX that does everything but scratch your nuts Of course, I could never get past 2W without someone complaining.... from across the street ha ha. Link to comment Share on other sites More sharing options...
