steveb40 Posted October 19, 2004 Share Posted October 19, 2004 I've recently purchased a K-3. Is there an inexpensive macro lens I could find for it? THANKS Link to comment Share on other sites More sharing options...
andrewbuchanan Posted October 19, 2004 Share Posted October 19, 2004 Look for the Zeiss lenses made in the DDR (before it's fall) I think there is a macro or two in that collection... the name of which escapes me right now... but go on ebay do a search for M42 (or practica) and Zeiss. This should give you some results - whether you buy there or not. Good luck. Link to comment Share on other sites More sharing options...
steveb40 Posted October 20, 2004 Author Share Posted October 20, 2004 Look for the Zeiss lenses made in the DDR (before it's fall) I think there is a macro or two in that collection... the name of which escapes me right now... but go on ebay do a search for M42 (or practica) and Zeiss. This should give you some results - whether you buy there or not. Good luck. <{POST_SNAPBACK}> OK. So I'm going to buy a Zeiss DDR 50/1.8. I think it'll do it. Is it a good choice? THANKS Link to comment Share on other sites More sharing options...
steveb40 Posted October 21, 2004 Author Share Posted October 21, 2004 Lost a bid on a zeiss ddr. bought an old meyer oreston 50/1.8. will this yield better results than the stock K-3 glass? THANKS Link to comment Share on other sites More sharing options...
andrewbuchanan Posted October 21, 2004 Share Posted October 21, 2004 Lost a bid on a zeiss ddr. bought an old meyer oreston 50/1.8. will this yield better results than the stock K-3 glass? THANKS <{POST_SNAPBACK}> I don't know, I've only used my nikons... I hear the Zeiss are very good though. Actually I used a 20mm Mamiya-sekor that was very sharp and fast... and CHEAP. Remember that a 50mm will look a lot more like 100mm in 16mm format... get a 24mm or a 25mm if you want normal perspective. Good luck. Link to comment Share on other sites More sharing options...
steveb40 Posted October 21, 2004 Author Share Posted October 21, 2004 I don't know, I've only used my nikons... I hear the Zeiss are very good though. Actually I used a 20mm Mamiya-sekor that was very sharp and fast... and CHEAP. Remember that a 50mm will look a lot more like 100mm in 16mm format... get a 24mm or a 25mm if you want normal perspective. Good luck. <{POST_SNAPBACK}> Andrew, So the one I bought (50mm) will be a telephoto? Thanks for all the help. I'm trying to get the hang of this. Link to comment Share on other sites More sharing options...
andrewbuchanan Posted October 22, 2004 Share Posted October 22, 2004 Andrew, So the one I bought (50mm) will be a telephoto? Thanks for all the help. I'm trying to get the hang of this. <{POST_SNAPBACK}> Yep. The 16mm frame is like taking the very middle forth or fifth of a 35mm frame. So, while you still technically have a 50mm... it will look a lot more like a 100mm on the much smaller frame size (I'm sure someone on this forum will call me out for that lame explanation). BUT it is the case. That is why the high end Optar and Zeiss primes sets for 16mm and s16 are something like 9mm, 12mm, 18mm, 24mm, 32mm and 50mm (I'll get called out on this too)... because the 32mm and 50mm cover the telephoto end of things. If it is any consulation, telephoto lenses are usally a lot sharper and I love to shoot with them as often as possible... plus with all the racket the K3 makes when it is running, you might find this to be advantagous. I wish I had all the used lenses of New York to pilfer, fondle, and discover... there isn't much in North Carolina. Link to comment Share on other sites More sharing options...
steveb40 Posted October 23, 2004 Author Share Posted October 23, 2004 Yep. The 16mm frame is like taking the very middle forth or fifth of a 35mm frame. So, while you still technically have a 50mm... it will look a lot more like a 100mm on the much smaller frame size (I'm sure someone on this forum will call me out for that lame explanation). BUT it is the case. That is why the high end Optar and Zeiss primes sets for 16mm and s16 are something like 9mm, 12mm, 18mm, 24mm, 32mm and 50mm (I'll get called out on this too)... because the 32mm and 50mm cover the telephoto end of things. If it is any consulation, telephoto lenses are usally a lot sharper and I love to shoot with them as often as possible... plus with all the racket the K3 makes when it is running, you might find this to be advantagous. I wish I had all the used lenses of New York to pilfer, fondle, and discover... there isn't much in North Carolina. <{POST_SNAPBACK}> thanks for the info. yes, sometimes i like this town. i found a 29mm meyer pentacon so now i'll have two primes. i look forward to testing both when i get the camera. i feel good about using the 50mm since, as you say, it should produce some nice, sharp images. i'll report back. Link to comment Share on other sites More sharing options...
