Hi all, and specifically Jan! I have a DVCPRO50 tape that has hot whites (+100) and somebody suggested I go into the 930 menu and pull down the video setting in the SYSTEM menu. Do/can these changes effect the firewire output or just composite/component/SDI?
I want to change the settings for the firewire output, but i am thinking that the firewire just reads the info straight off the tape, as is.
  • 2 weeks later...
Firewire output is "baked in" so to speak. You can of course tweak to your hearts content once you capture into your NLE but coming off the deck it's unchangeable from Firewire.
Noah
First sorry for the delay, I have been out of the country on a Honeymoon. ;-) Paris, Tuscany, Amsterdam, nice.
Anyhow as Noah said, any corection you make will not affect the Firewire output, as it is leaving the deck before the proc amp, per se. I would say transfer and correct in the NLE.
Hope that helps,
Jan
