LangISback Posted October 23, 2004 Share Posted October 23, 2004 I just bought a 16mm Ampro projector, very old but seem to work just fine, the mechanism runs smooth and the lamp is very bright. I ran on it a negative I made to test my 16mm camera, which has the rank prep white leader. The problem was this: The white leader ran just fine (about 20 secs), it is single perf. But, when the double perf. negative entered the sprockets, the projector mechanism started to make a loud noise and the negative came out with big damage on the sprocket holes. At some point the negative even broke. I want to know if the problem is with my projector or if I can't play negatives on 16mm projectors or if there is some issue with the a-wind b-wind thing. Any help would be much apreciated. regards! Link to comment Share on other sites More sharing options...
