Andrew Bassett Posted June 21, 2008 Posted June 21, 2008 I'm selling my letus extreme after using it on only one project. It is in near perfect condition. There is slight wear near the screw hole for the support bracket on the underside of the letus but does not affect the performance at all. I modified the support bracket a little but it works the same if you use a washer with it. I'll also throw in a set of indifocus 18in rails. $1100.00
Andrew Bassett Posted June 29, 2008 Author Posted June 29, 2008 is it 72mm?what lens moumt? It is an 82mm lens mount. It directly attaches to the hvx. I also have several step up rings that I am including so that you can use it with different cameras. 43-58mm 58-72mm 72-82mm If you used all three you can attach the letus to a very small camera. we were using it with an hv20!! It comes with a nikon lens mount.
Andrew Bassett Posted July 22, 2008 Author Posted July 22, 2008 Here is a still from our shoot featuring the letus on a canon HV20.
