Seth C King Posted October 27, 2008 Share Posted October 27, 2008 Here are the specifications of the rod support. The rod support is designed to attach directly to the bottom of the camera's handle, therefore eliminating any modifications to the camera itself. It attaches with a standard 1/4-20 screw that is supplied and then can be mounted to any tripod plate equiped with a 1/4-20 screw. Most tripods and plates accept either 1/4-20 or 3/8". The rods are industry standard 15mm diameter and 60mm rod center to rod center, meaning that they'll accept any mattebox or follow focus with these measurements. Rod lengths are 9". The rod support was also designed to allow handheld use, with a certian level of comfort, as can be noted by the rounded edges on the back of the unit. The unit has horizontal and vertical fine adjustments. If you have several cameras, you may have to make adjustments for each camera. The unit is a special order item and is made when you order it. Therefore, delivery is three weeks from date of order. The unit sells for $250.00 + $8.50 S&H (including insurance) and includes a simple instruction sheet for installation and the necessary tools for adjustments. You have 7 days, from date of delivery, to return it if you're not completely satisfied for a full refund of the purchase price. If you have any other questions, please feel free to email me. Thanks, Seth C. King Link to comment Share on other sites More sharing options...
Seth C King Posted November 9, 2008 Author Share Posted November 9, 2008 Reduced price. $170.00 plus $8.50 shipping and handling. Link to comment Share on other sites More sharing options...
