Jason Mann Posted November 15, 2004 Share Posted November 15, 2004 I'm working on a doc that I've shot in 24P Advanced on a DVX-100A. I had planned on removing the pulldown on capture and working in a 23.98fps sequence in Final Cut. My two questions: I have a couple of hours of archival footage that was shot on a very basic Hi8 handycam, and I'd like to incorporate it. I can dub it to mini-DV, but then it will be 60i, right? How can I cut it into 24p material? Secondly, I think I'll be outputting to a high resolution format at the end of the project (maybe DigiBeta?) Will these formats be a problem if my source material is 24p? Thanks Link to comment Share on other sites More sharing options...
Noah Kadner Posted November 15, 2004 Share Posted November 15, 2004 You could convert the 60i material to 24p via the DVFilm Maker program- dvfilm.com For output to Digibeta you'd need either a BMD or Kona card or would simply output to DV and then dub to DigiBeta. The 3:2 pulldown would be added back in as you playback in either case. Noah Link to comment Share on other sites More sharing options...
Jason Mann Posted November 15, 2004 Author Share Posted November 15, 2004 Would there be a difference in quality between those two options, Noah? Link to comment Share on other sites More sharing options...
