Sergey Kravchenco Posted June 16, 2009 Share Posted June 16, 2009 (edited) Up for sale NEW not used earlier - Ecran ( now Optica Elite ) anamorphic Zoom lens F = 50 - 160 , T = 5 and afer replace anamorphic adapter - you can shooting with normal zoom F = 25-80 /3 , T = 3.4. Lens not used earlier .Lens converted on PL mount and mounted ARRI standard focus and zoom gear rings .Glass is fine , multicoating not damage . Ser N 880001 .Lens cover format 35 mm - 4K for RED One camera .It is one of the best compact Zoom lenses extra sharpest and very contrast .Light weight - need not support - weight only 1.3 Kg ..It is possible to use zoom lens without rear anamorphic adapter ( PL mount attach ) , in this case Zoom lens will has F = 25 - 80 / 3.4 - you must replace anamorphic adapter and to fit gasket ( including in set ) for normal non anamorphic lens - need not collimate after it .During 5 minutes you can has normal zoom non anamorphic with F = 25-80 / 3 . In set hood and two front diopters lens 0.4 and 0.6 - see on photos .Lens comes in original case Technical date for anamorphic zoom : F = 50 - 160 mm T = 5.0 ================= Normal zoom ( not anamorphic ) : F = 25-80/3 T = 3.4 Close focus - 1M Length - 180 mm Weight - 1.3 Kg Visual resolving power = 100 1/mm lines in center Focus scale engraving in meters .Lens has front and rear caps . Lens comes with warranty . Below you can find some photos of this lens . Asking $ 6000 + shipp. Lens very compact and light weight - NEED not support !! If you have any question or additional information - please contact with me : sergastr@list.ru sergastr@yahoo.com Best regards Sergey Kravchenco P.S. - see link below with photos : http://www.reduser.net/forum/showthread.php?t=31528 Edited June 16, 2009 by Sergey Kravchenco Link to comment Share on other sites More sharing options...
