Guest Steadicam Forum Posted July 7, 2010 Share Posted July 7, 2010 Excellent condition Scorpio remote focus unit with motion generator encoder included. Includes 3 motors plus all the cables and backup cables you can imagine including a Scorpio MDR cable to an optional preston motor. Hand unit has had upgrades to the battery unit (Sony system), as well as a Preston antenna system. Also included are various motor brackets and extensions, monitor plates, optional pistol grip, 4 Sony batteries and charger. Recently serviced and inspected by ‘Cramped Attic Technologies’ of Vancouver. Hand unit MDR 2 Preston antennas 3 Digital motors 5 Motor brackets 14 Focus rings Panavision 4 Motor cables including right angle –green 1 Preston/Scorpio motor cable 2x 10’ Pana cable XLR with Scorpio camera switcher (Lemo/Fisher) 1 Pana power (Large fitting) to 2 pin lemo cable (very short cable) 1 Pana command (on/off) driver cable 3x 3 pin Donkey box power (11/30vdc) to 24V Pana Lemo 1 Panavision focus gear 1 48 pitch gear (Panavision Zoom) 1 64 pitch gear (Panavision Iris) Hex screws Kip screws 4 Sony Lithium Hand unit batteries 1 Sony Lithium Hand unit battery charger with cable 3 Arri bushings (blue) 6 Panavision bushings (brass) 1x .89mm Allen key for scorpio motor 1 Panavision motor focus bracket -(slides into Front body focus mount) 1 Donkey box/shoe bracket -(slides onto lens light bracket) 1 Support rod motor bracket -(slides onto Pana zoom rod bracket) 1 silver 2 ½” 15mm rod 1 silver 3 ¼” 15mm rod 1 silver 4” 15mm with 3/8 – 16 threaded stud rod 2x 2” Blk female/female 1x 2” 90* offset female/female Arri 2x 3 pin Fisher to Arri 3 pin R.S. power cable (on board 11/30 vdc) -yellow 1 Hand set to Donkey box cable “0” setting –red/white 2x 4 pin XLR to Donkey box power cable (11/30 vdc) –brown 1 Arri control cable BL-IV SRII Arri III 2 Arri 535/435/SR3 Command cables (camera run on/off) –blue 1 Handset power cable to 4 pin block battery 2 Scorpio power 12v 2 Arri run/stop 1 Manual 1 monitor plate for handset 1 round black handle 1/2” roll of yellow electric tape Pelican case A rarely used motion generator. The motion generator encoder is primarily used for creating the ‘Dolly in’, ‘Zoom out’ effect and vice versa, while still maintaining the same frame size. Automates the zoom and focus features with optional manual override. Includes: o Encoder with locking arm and maffer clamp assembly (cable end attaches to Scorpio MDR) o 24ft Kevlar belt (runs along dolly track) o 2 modified maffer clamps (for the Kevlar belt) o 2nd full size pelican case A great value at nearly half the original cost, with thousands of dollars worth of cables and specialized machined brackets. Asking $18,000 USD Chris pleade@shaw.ca View or reply to the original post at SteadicamForum.com Link to comment Share on other sites More sharing options...
