Guest Steadicam Forum Posted September 15, 2010 Share Posted September 15, 2010 Steadicam Clipper 24 / NEW G-50 Arm Complete System – Sled, Arm, Vest & Cables !! Price Reduced to $36,995.00 !! PLUS: Includes Three Day Private One-on-One Steadicam Workshop with One Day Business Course and Custom Business / Marketing Plan Over 90 Photos! - Click Here Steadicam Clipper 24 12 and 24 Volt ready - with many custom upgrades: built in Video DA in top and bottom stage, HD ready (add an HD monitor and you are good to go), Ready for film, video, HD and live show work (Tally, inputs for Program monitor, etc.) Tilt stage and three section center post, included is the standard def 7" LCD Monitor with built-in frame Lines. NEW never used G-50 arm and Ultra2 vest. SLED Clipper 24 Hi-Def sled with Custom mods Open Design Tilt stage (15 degree) Composite Telescoping Center Post, no tools, three section Low Friction Gimbal Color Day-bright Composite NTSC/PAL 7" Monitor with Frame lines - 700 nits V-mount IDX steadicam Power system Rain gear for Sled and Monitor (set of three) ThermoDyne Sled Hard Case Power: IDX VL-2 Plus Quick Charger - NEW AC Cable IDX Lithium-Ion Endura 10 Battery (2) ThermoDyne Batteries & AKS Hard Case G50 ARM NEW NEVER USED 2010 Geo G-50 Dual articulated Iso-Elastic Stabilizer Arm with ride control 10- 33lb (4.5-14.9kg) Net camera Capacity Includes arm adapter for Ultra/Clipper Sled as well as for Flyer/Provid G-50 Soft case VEST Ultra2 Vest with brand-new Pads, never used. Steel full size Socket Block Steel Flyer Socket Block with Bridge (to use a flyer arm with the Ultra vest) New and never used spare complete Vest Pad set Bad weather spare Vest Pads (used) Misc. Back-up Screws, Buckles & Straps ThermoDyne Vest & Arm Hard Case BRACKETS Dovetail Plate 9" Standard Length (2) Dovetail Plate 7" Short Length Low mode "F" Bracket (new model) Low mode adapter Bracket for Video cameras Hill Docking bracket and 2 inch Gorelock Hill 2" Docking Collar to 1.58" Post (Highmode) Hill 2" Docking Collar to 1.685" Post (Lowmode) CABLES HD-SDI 7-Pin Lemo to BNC Cable (3) HD-SDI 7-Pin Lemo to BNC w/Tally Connector Cable HD-RGB/Data Breakout Cable 7-Pin Lemo to RGB Cable 3' Mogami 1354 BNC to BNC Cable Photo Electric Optical Tally Sensor Monitor Cable w/Lemo Tally Connector (2) Monitor Cable w/Molex Tally Connector Monitor Cable No Tally Connector Monitor Cable Coiled 4-Pin Hirose to 7" LCD Lemo Monitor Cable 6-Pin Hirose to 7" LCD Right Angle Lemo Monitor Cable 6-Pin Hirose to 7" LCD Lemo Monitor Cable 8-Pin Lemo to 8-Pin Lemo Clipper 24v Lemo Power to Bare wire Pigtail Clipper 3-Pin Lemo Power to Master Series 2-Pin Female Adapter Camos LCD Power from Sled Cable 12v Power to Video Camera Cable (3) Panavision 24v Power Cable RED Camera 12v Power Cable ARRI 24v Power Cable Moviecam 24v Power Cable CanaTrans Power & Video Cable Stanton Y power cable Misc. Back-up Screws, Fuses & Parts for Sled and Vest Less then 3 years old. Very well cared for. Just completely tested, serviced and upgraded to the latest specs by Tiffen. Tons of new and/or never used parts. Reason for sale: Outgrown… Moved to bigger rig / arm with larger Payload. Over $52,000 new – Price Reduced to $36,995.00 including three day private workshop and business course in Las Vegas Buyer pays all costs of shipping and/or import duties if applicable. Available for pick up in Los Angeles or Las Vegas. VISA / MasterCard / AMEX accepted! Financing / Leasing available for qualified individuals through Summit Commercial Finance. I'm a motivated seller and will consider all REASONABLE / RESPECTABLE offers! Robert Starling, SOC 702 810-5707 robert@westcoaststeadicam.com View or reply to the original post at SteadicamForum.com Link to comment Share on other sites More sharing options...
