Scott Imler Posted February 8, 2005 Share Posted February 8, 2005 Hey anybody out there had to change heads on their SDX 900? I am curious what the average amount of hours before the heads need changing. I own a 400A Beta Sp cam and they would last anywhere from 900-1400 hours of drum running, curious how the 900 compares. Looking at buying a used 900 so any info on this would be helpful. Thanks in advance Link to comment Share on other sites More sharing options...
Jan Crittenden Posted February 9, 2005 Share Posted February 9, 2005 Hey anybody out there had to change heads on their SDX 900? I am curious what the average amount of hours before the heads need changing. I own a 400A Beta Sp cam and they would last anywhere from 900-1400 hours of drum running, curious how the 900 compares. Looking at buying a used 900 so any info on this would be helpful. Thanks in advance <{POST_SNAPBACK}> For the most part about 2000 hours is about the shortest I have seen. Certainly others have lastest much longer. The primary difference in the tape tension in the DVCPRO50 cameras is about a 1/4 of that in Beta SP cameras. Makes a big difference. Hope that helps, Jan Link to comment Share on other sites More sharing options...
Scott Imler Posted February 10, 2005 Author Share Posted February 10, 2005 For the most part about 2000 hours is about the shortest I have seen. Certainly others have lastest much longer. The primary difference in the tape tension in the DVCPRO50 cameras is about a 1/4 of that in Beta SP cameras. Makes a big difference. Hope that helps, Jan <{POST_SNAPBACK}> Thanks Jan I knew it wsa higher just not sure how much higher good to know Link to comment Share on other sites More sharing options...
